| Forum Home > Parts Info, Tech Tips and Tinkering > Sticky: The all-too-common Displaced Finger Tension Spring chrono' sweep hand problem | ||
And so it goes on - unabated. Don't you just love it when an eBay seller posts a close-up of his cock-up. This morning, a German eBay seller listed a 7A38-7240, with an over-optimistic 'pie-in-the-sky' Buy-it-Now price of 299 Euros. It's in average worn condition, but unusually (for this model) still fitted with its correct original two-tone bracelet. http://www.ebay.co.uk/itm/202688130676 Seiko 7A38-7240 Chronograph Day Date 80er Rarität Quartz Top Zust. Originalband The English language part of the seller's description includes the following: MOVEMENT: Quarz 7A38 WORKING PERFECTLY. THE CHRONOGRAPH IS WORKING PERFECTLY. Movement is in working order and keeps good time. All Funktions are working properly! You´ll buy what you see at the pictures.
![]() Member Posts: 9 | Can the spring also be displaced vertically? https://photos.app.goo.gl/6kCPxRty8PagvVGd6 | |
I wouldn't describe yours as 'displaced vertically' - more like bent upwards, Hanson.
With the more common lateral displacement, you can sometimes just flick the finger tension spring back into place with the point of a cocktail stick. Though I find it pays to loosen the retaining screw, to re-position it perfectly central over the jewel / axle. But you will need to remove yours and carefully bend / twist it back into shape - with the emphasis on carefully. It's very thin stainless spring steel. You really only get one chance. If you try re-bending it a second time they usually snap. PS - You may already have noticed, but your Alien's movement is also missing the rotary step switch. | |
Hmm.. I may leave it for my watchmaker then. Nope didn't realise that! Thanks Paul This Aliens project watch is finding new ways to make me realise that I didn't get the bargain I thought I did haha.. The NOS crown I just received from eBay has a broken off stem inside, although listed as New. Seiko Oceania have the steel crown 45M60NS1 in stock which I might see if they actually have, and then get it powder coated black... | |
Here's another example of this classic self-inflicted cock-up, by someone who really ought to know better. Firstly as a 7-day auction, with an opening bid price of 1 cent (0.01 Euros). http://www.ebay.co.uk/itm/264496448788
Again, in parallel, as a Buy-it-Now for an absolutely ludicrous 333.33 Euros. http://www.ebay.co.uk/itm/264496447812
Check out his last photo in both listings:
His two indentical descriptions both include the same phrase: .... come funzionante completamente e perfettamente. Which translates as: as working completely and perfectly. I really don't see how, Daniel. | |
![]() Member Posts: 5 |
Just received mine and the same thing. I saw it couldn't be right so googled some open caseback images, spring was to the side like the pic above.. The Renata battery also weeping slightly with signs of moisture. a few drops and a small amount of green. Got a Seiko battery on the way tho apparantly Eveready and Sony are rated better? | |
Given that most instances I see of this classic self-inflicted fault are in eBay listings, it makes a refreshing change to see an eBay seller who has actually bothered to read this thread, even if he didn't understand the ramifications. This partly functional well-worn 7A38-7240 was listed overnight by a US eBay seller as a 5-day auction (albeit with an over-optimistic opening bid price of $139.95): http://www.ebay.co.uk/itm/133231827811
Fresh from an Estate Sale, you are bidding on a Very Desirable Vintage 1987 Men's Seiko 7A38 Chronograph with Day/Date Calendar that started to Run when a New Battery was Installed, however, it has some issues. I am not a watch repairperson, just Battery Changer, but I did some research and it may be related to the Friction Installed Cannon Pinion, that may have loosened up. So, when the Minute, Hour and Sub Minute hand do not function (meaning gain time, when all the other hands are rotating), it may be the Cannon Pinion is slipping. Just to mention something else I found on a Seiko 7A38 online blog. If you notice in the pictures of the movement, you see a little arm in the center that covers a jewel, where I guess on the other side is the Cannon Pinion. If I read it correctly, in the blogs, it says that the spring/tension cover needs to actually cover that jewel. That's why the hands won't rotate, so I did move it over to cover it and still nothing happened. I am still leaning toward the slipping pinion. Anyway, I leave it to you to figure out. | |
The Kamatz 519000 'Tango Charlie', which I'd bought off eBay in the States last week, and which was delivered this morning, arrived with a distinctly recalcitrant sweep second hand. I'd expected it. The seller had written in the item specifics: NEW BATTERY INSTALLED - KEEPS TIME BUT SECOND HAND NOT MOVING No guesses as to the culprit - yet another deftly deflected finger tension spring.
I slackened off the retaining screw a turn and flicked it back into place ....
That isn't quite as bad as it might appear. It's not a groove worn in the end of the finger tension spring, but a build-up of dirt, filings and old oil. But just to be sure the end of the axle was still intact, I removed it completely to check underneath.
Earlier this week, I won a UK eBay auction for a Yema N81W63 Breguet Classique clone. It wasn't as if I really needed another of these blingy Yema N8's, but I simply couldn't pass it up at the price. http://www.ebay.co.uk/itm/133351412562
It arrived in the post at lunchtime today. Initially, everything looked fine and dandy, but on a second try of the chronograph self-test, the sweep second hand appeared to hesitate moving off its mark. Here are the seller's two photos of the movement, taken from the eBay listing:
Note the photos (presumably taken at different times) show two different batteries fitted: a Rayovac #371 and a Seiko SR927SW (#399 equivalent) - both undersized. Guess what I found when I unscrewed the case-back ?
Yet another different under-sized battery - this time a Renata 395 .... Oh and the classic self-inficted fault - a deftly deflected finger tension spring. | |
