If you examine an original Seiko crystal – either the old one you have pressed out (or if you’re fortunate to have a NOS genuine Seiko replacement), apart from possibly having a polished decorative top bevelled edge, you will notice that it also has another ‘lead in’ bevelled edge ground on the underside. It is this ‘lead in’ edge which facilitated fitting the crystal, in the factory when the watches were made. It is this ‘lead in’ bevel which leaves the tell-tale ‘step’ indentation in the original gasket, where it doesn’t compress the gasket for its entire depth. As you know, I am an advocate for fitting Sternkreuz toughened glass replacement crystals, particularly their MSM range. I can’t say that they are any harder (in terms of scratch resistance) than Seiko Hardlex, but they certainly are stronger, particularly if you give them ‘a bit of welly’ pressing them back in. I have never once broken a Sternkreuz crystal pressing it back in, but I have shattered the odd Seiko Hardlex (pressing them out), and cracked a few Cousins ‘cheapies’ pressing them in, in my early days.
The other thing I like about using Sternkreuz MSM crystals, is that they usually have NO ‘lead in’ chamfered edge. The edges of the crystal are ground straight and parallel. That may make them harder to 'seat squarely' initially - and to press in, but it also gives you a ‘second bite’ at the lower part of the original Seiko crystal gasket.
